Z-suite 3.6.0.0 does not save extrusion temperature
There seems to be a bug in Z-suite 3.6.0.0. When I select Z-ABS and adjust extrusion temperature, save and close the project, then after re-opening the project the extrusion temperature is 275C which is the default value. Exporting to zcodex2 file works correctly.
