Z-Suite and Inkspire copy object with supports
Hi, I apologize if I insert topic continuously, I just started to use the Z-Suite software with the Inkspire printer. I have a lot of experience with other similar printers and print management software, so I’m used to using features that I can’t find in the Z-Suite. I suggest adding a function that allows you to make multiple copies of the same object and make copies of objects after generating supports.
Hi Faber61, its already in Z-Suite. Just add one model, generate support, go to Preview step, and choose “Replicate” tool, enter number of copies, and its ready.
Hi, thank you. The command you have indicated serves me only if I have only one object on the plate and I have to reply to it. But if on the plate or several different objects the button is not active and I cannot use it
Fabrizio
