Hi, I don’t understand why if I have to change even a single parameter (change the type of resin) or delete an object from the dish the program deletes all the supports. I can’t waste time every time putting back the media manually since the software inserts the media in places where they are not needed or on details. I print very small pieces and on a plate I have to put several different objects and often modify the print by adding or removing objects.
Please do something about it.
Hi, I can see your point. Thank you for your feedback. We will pass it to our specialists for further consideration.
