Javi
#1
Im having problems converting an stl to zcode. The stl file weights 5 mb and has a lot of text in his walls.
Zsuite printing option:
MACHINE ZORTRAX M 200
MATERIAL Z-ABS
LAYER THICKNESS 0.19
SURFACE LAYERS : TOP 3 BOTTOM 3
SPEED NORMAL
INFILL LIGHT
NO SUPPORT
FAN SPEED AUTO
SEAMS NORMAL
I tried to modify but without succes. I checked the mesh of the stl and it seems to be correct.
Any idea?
Thanks!!
Can you share the STL file?
Chris
#3
Dear Javi,
please share an .stl file so we can perform diagnostics.
Javi
#4
Sorry its been a long time.
I was able to generate the code but it takes about 6 hours. The part I was trying to make has a lot of geometric features and a lot of text.
I think the problem is the text.
Thanks @Chris @MichaelHenry
Have you tried any of the more recent Zortrax Z-Suite versions? The last one or two seem to slice much faster than earlier versions.
Javi
#6
Yes I did with Zsuite v1.7.0 and with an older version (v1.4.1) and it takes more or less the same time
Marcin
#7
Can you get me an STL and desired settings?
