All files save as only 16kb and these are huge models.
The opening creates an error and says the file is correct. Tried on several machines and with several models.
Those are Gigabyte or more models.
Hi @Montrose,
You are using Z-SUITE Beta, right? Please, check if the same issue occurs with Z-SUITE 2.21.0 as well. Also, make sure you have enough space on the disk, as this may also prevent files from being saved correctly. Moreover, choose a different location to save your file (for example, to your desktop).
