I'm having issues with surface finish on the bottoms and tops of parts with Z-Suite 1.4.1 and wanted to try older versions to see if they worked any better. When I try to run any version of Z-Suite older than 1.4.0 the program fails to load and I get the error message in the screen grab below. Has anybody else seen this problem? Is there a solution?
I've filed a Bug Tracker report.
