Hello Pawel,
I run Mac OS 11.6 (Big Sur) and I have never used or installed any Z-Suite SW before. Currently I am running the latest stable release but if you prefer I can install the 3.0 Beta. I have done that before and it behaved the same way.
Please see below the output from the Z-Suite when executed from a terminal.
Thank you so much for you help!
Richard
[ERROR] FATAL UNHANDLED EXCEPTION: ObjCRuntime.RuntimeException: Failed to lookup the required marshalling information.
Additional information:
Selector: conformsToProtocol:
Type: ViewController
—> ObjCRuntime.RuntimeException: Failed to get the ‘this’ instance in a method call to A…InvokeConformsToProtocol. —> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.UnauthorizedAccessException: Access to the path ‘/Users/stahl/.config/Zortrax/’ is denied. —> System.IO.IOException: Permission denied
— End of inner exception stack trace —
at System.IO.FileSystem.CreateDirectory (System.String fullPath) [0x00192] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/external/corefx/src/System.IO.FileSystem/src/System/IO/FileSystem.Unix.cs:319
at System.IO.Directory.CreateDirectory (System.String path) [0x0002c] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/external/corefx/src/System.IO.FileSystem/src/System/IO/Directory.cs:40
at A… () [0x0000c] in <1f33526fd4f7436782a18f37c62456d4>:0
at A.
…ctor (System.String , A. , A. , System.String[] ) [0x000b7] in <1f33526fd4f7436782a18f37c62456d4>:0
at A…ctor (System.IntPtr ) [0x00154] in <4793ce6ce9234a27bd05905834de3fbe>:0
at (wrapper managed-to-native) System.Reflection.RuntimeConstructorInfo.InternalInvoke(System.Reflection.RuntimeConstructorInfo,object,object[],System.Exception&)
at System.Reflection.RuntimeConstructorInfo.InternalInvoke (System.Object obj, System.Object[] parameters, System.Boolean wrapExceptions) [0x00005] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/mcs/class/corlib/System.Reflection/RuntimeMethodInfo.cs:936
at System.Reflection.RuntimeConstructorInfo.InternalInvoke (System.Object obj, System.Object[] parameters, System.Boolean wrapExceptions) [0x00018] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/mcs/class/corlib/System.Reflection/RuntimeMethodInfo.cs:944
at System.Reflection.RuntimeConstructorInfo.DoInvoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00086] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/mcs/class/corlib/System.Reflection/RuntimeMethodInfo.cs:926
at System.Reflection.RuntimeConstructorInfo.Invoke (System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/mcs/class/corlib/System.Reflection/RuntimeMethodInfo.cs:960
at System.Reflection.ConstructorInfo.Invoke (System.Object[] parameters) [0x00000] in /Library/Frameworks/Xamarin.Mac.framework/Versions/Current/src/Xamarin.Mac/external/corefx/src/Common/src/CoreLib/System/Reflection/ConstructorInfo.cs:22
at ObjCRuntime.Runtime.ConstructNSObject[T] (System.IntPtr ptr, System.Type type, ObjCRuntime.Runtime+MissingCtorResolution missingCtorResolution) [0x00045] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/ObjCRuntime/Runtime.cs:1123
at ObjCRuntime.Runtime.ConstructNSObject (System.IntPtr ptr, System.IntPtr klass, ObjCRuntime.Runtime+MissingCtorResolution missingCtorResolution) [0x00014] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/ObjCRuntime/Runtime.cs:1098
at ObjCRuntime.Runtime.GetNSObject (System.IntPtr ptr, ObjCRuntime.Runtime+MissingCtorResolution missingCtorResolution, System.Boolean evenInFinalizerQueue) [0x00028] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/ObjCRuntime/Runtime.cs:1230
at Registrar.DynamicRegistrar.GetMethodDescriptionAndObject (System.Type type, System.IntPtr selector, System.Boolean is_static, System.IntPtr obj, System.IntPtr& mthis, System.IntPtr desc) [0x00056] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/ObjCRuntime/DynamicRegistrar.cs:862
at Registrar.DynamicRegistrar.GetMethodDescriptionAndObject (System.Type type, System.IntPtr selector, System.Boolean is_static, System.IntPtr obj, System.IntPtr& mthis, System.IntPtr desc) [0x000a0] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/ObjCRuntime/DynamicRegistrar.cs:869
at ObjCRuntime.Runtime.GetMethodAndObjectForSelector (System.IntPtr klass, System.IntPtr sel, System.Boolean is_static, System.IntPtr obj, System.IntPtr& mthis, System.IntPtr desc) [0x00001] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/ObjCRuntime/Runtime.cs:738
at ObjCRuntime.Runtime.get_method_and_object_for_selector (System.IntPtr cls, System.IntPtr sel, System.Boolean is_static, System.IntPtr obj, System.IntPtr& mthis, System.IntPtr desc, System.Int32& exception_gchandle) [0x00006] in /Users/builder/azdo/_work/1/s/xamarin-macios/runtime/Delegates.generated.cs:416
at (wrapper managed-to-native) AppKit.NSApplication.NSApplicationMain(int,string[])
at AppKit.NSApplication.Main (System.String[] args) [0x00040] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/AppKit/NSApplication.cs:109
at A. (System.String[] ) [0x00005] in <4793ce6ce9234a27bd05905834de3fbe>:0
