either Z-Suite writes the Z-Code different from what is showed or the Firmware does not print what it should?
It's most likely Z-Suite, can I get ZCODE / STL ?
This model is still work in progress, actual version changed so I would have to get it from a backup (too lazy for that, think STL is not relevant).
Z-Code attached.
I've printed it. Looks slightly different but definitely - there is something going on there.
I could reproduce it with the newer version STL also (same location).
I think it is related to the starting point of the support structure and a firmware issue.
Well I must admit, you guys always admit to any fault with your software, which is a good thing.
I just received my M200 yesterday and installed installed Z-Suite_V1.11.4 for Windows on my laptop (Windows 10).
Why I do not see advanced printing setting on my Z-suite? According to the website, it should be just below the "FAN speed" option.
I do not see it there. See below a screenshot of my Z-suite.
I found the issue. I have a 14" laptop, so in the view Z-suite was not showing options below the "fan speed". The screen is too small and Z-suite does not provide a bar so you can drag down and see the options. It just does not show them!
