Hi there
Is there any information about the temperatures and printing speeds at the different profiles?
Are the speeds the same in all profiles (ABS,Ultrat,...)? Differs it only with the quality settings?
Hi there
Speed differs between materials, layer heights, infills and quality. I wont share exact values though.
Same for the temperature, you can search over the forum, someone measured it.
Values used in 1.5.x:
UltraT Plus 150µm, 200µm
260° / 60°
UltraT 200µm, 150µm, 100µm
260° / 80°
PETG 200µm, 150µm
254° / 30°
PCABS 200µm, 150µm
290° / 105°
HIPS 300µm, 200µm, 150µm
255° / 80°
Glass 300µm, 200µm. 150µm
254° / 30°
ABS 400µm
277° / 80°
ABS 300µm, 200µm, 150µm, 100µm
275° / 80°
Feedrate for contours is 1200mm/min for all materials/layer thicknesses. Infill is typically 2400mm/min.
There are other speeds used for other scenarios though between 600mm/min (raft base) up to 4000mm/min (fast infill).
