Z-Suite Shortcuts
General:
CTRL - Z   ->   Undo
CTRL - Y   ->   Redo
CTRL - RIGHT mouse button   ->   Select more models
CTRL - A   ->   Select all models
CTRL - C   ->   Duplicate selected models
DELETE or BACKSPACE key   ->   Delete selectred models
View:
+ key   ->   Zoom in
- key   ->  Zoom out
LEFT ARROW key   ->   Rotate view right
RIGHT ARROW key   ->   Rotate view left
UP ARROW key   ->   Rotate view down
DOWN ARROW key   ->   Rotate view up
Rotate:
CTRL - LEFT and RIGHT mouse movements  ->  Rotate selected models around selected axis in 5° steps
Move:
CTRL - UP and DOWN  mouse movements  ->  Resize selected models in 10% steps along selected axis or all axis
Split:
UP ARROW and DOWN ARROW key ->  Move split plane in 1mm steps along selected axis
Pause:
UP ARROW and DOWN ARROW key ->  Move pause plane in 1% steps along Z axis
thx for this
it would be convenient if we could have shortcuts for rotate objetcs, move objects and scale objetcs
not sure I'd want a shortcut for scaling objects... I'd hate to bump that key.
Do you do a lot of scaling?
I'm almost exclusively scaling by 25.4 to get from mm to inch. Maybe a "x 25.4"  and "/ 25.4" buttons next to the existing up/down arrow buttons would be helpful
Don’t be so… Imperialcentric! : )
The Form1+ software has a very nice feature... when it sees a very small object is imported it asks if you want to use inches or mm.  Just click "inches" and it rescales.  I've already messed up one print on the Zortrax by typing 24.5 instead of 25.4.  User friendly seems to be a Zortrax theme... I'm sure they will add such a feature sometime soon.
I just started designing in mm to start with it works much better all the way around
Why not just have design software export in mm? That's what I do.. I can't draw in mm.. lol
That's more clicks.  I'm using an old version of Inventor and as far as I know, it doesn't give you the option to design in inches and export in mm.  I have to change the document settings each time I create a .STL if I did it that way.  Its actually faster for me to change it in the Zortrax software each time.  The Form1 requires only one click.  Simplify 3D, which is the software I use on my open source FFF printer, lets you pick inches or mm in the settings so it always uses the one you selected there.  That's essentially zero extra clicks which is even better.
See if this works on your Inventor.. http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-59FB702C-F37A-4DEA-ADCF-51AD8A219C9B-htm.html
Mine only gives me the option for resolution.  Its Inventor 11 (not 2011).  I think its around 10 years old or so now.  Thanks for checking on that for me though.
I press and hold the left mouse key and move the mouse to move the part
I press and hold the right mouse key and move the mouse to rotate the part (or maybe vice versa)
Moving the mouse wheel zooms in and out
Nettfabb has a converter thats just a click and then export. easy peasy. lol
