z-suite stopps after 20% - urgend!
I need urgent help,
this stl.file file stops after 20 % path generation, with the old version it does not work either
https://dl.dropboxusercontent.com/u/17280579/Teil-01-01.zip
settings:
z-ultrat
0.14 mm
fast
30 deg support
autofan
random seam
please...
Andreas
Here is the zcode after 20%...
https://dl.dropboxusercontent.com/u/17280579/Teil-01-01-zcode.zip
best
Andreas
seems to be that changing some settings worked as a workaround....
ultrat
0.14
fast
40 deg
fan 30 %
normal seam
556
Strange... This file works with the new Z-Suite version, the same that can't resolve a simpler file, the 4mm cover clip from Zortrax.
Maybe it is the infill, I think I used light the first time and medium the second time when it worked. …
I forgot to mention this…
I will try to narrow it down on monday…
I'm guessing normal vs random seam, as I've had some similar z-suite crashes.
I have had some models with this problem, only partly sliced - the top part missing. I can confirm that when I set seam from random to normal the model slices well again. So maybe a bug in the random seam setting.
I saw the same. Some models don’t work with random seam setting.
