Z-Suite strange error - "Cannot proceed"
Hi ...
What is wrong with this 3D model?
below:
- stl file
- sldprt (SolidWorks 2013) file
Scale down that file in SolidWorks or Z-Suite. It is more than 5m thick.
He needs a bigger printer... ;)
it is way to big I opened it in sketchup it is 54066.6 mm across
Hmm … but in SolidWorks everything is OK. All dimensions is in mm. Maybe reason is when I convert sldprt to stl ?
This is how I see it in SolidWorks:
5.1 meters :wink:
Exactly 5100 mm is 5.1 m even if it is in mm it's too large...
you must scale down the model in SW, if you scale the mesh you can have errors.
Opened it in Spaceclaim and it was HUGE too.. I scaled it down. I assume the small hole is 6mm..  https://www.dropbox.com/s/pjdrr5wxka46ewz/skoda_logo_tadeusz.stl?dl=0
