Sounds like a file issue. You say a mold....is the object you are printing split but together?
If its just hollow then I would check the file for errors and make sure there are no holes on the solid parts. Also, how thick is this piece?
Without the file I can't tell.
Good luck
Good luck
Thank you a lot. Can I send you the file to be sure?
Use the more reply options at the bottom of reply window and attach the file. Will check out and see whats going on
Here is the file. Thank you !
Your model is way too thin. The walls can't print if they are too thin. Plus there were multiple solids together. From what I am guessing is if this is a mold the bottom flat piece should be separate. I did a quick extrude of the walls but you will want to do it better yourself.
Sorry it took me all day to look at it. I fell asleep and just woke. lol
I wish I could sleep all day… Lol
