Z-Suite v1.0.0 won't give me a print preview of this (see .stl attached), so I can't save the code to print, but the previous s/w release/version did and it printed well.
This is for 0.09mm layers, which I did well last time, but now the finest that Z-Suite gives a print preview for is 0.14mm layers.
(the 4 wheels, still print at 0.09)
Why is this please_?
Same behavior reproduced here. STL file seems fine in both Netfabb and Meshmixer.
So does anyone know why Z-Suite v1.0.0 is not doing the STL file attached (above), but the previous s/w release did please_?
Andre
May 14, 2015, 2:57pm
Did you add it to the bug tracker?
I just tried, but it wanted me to attach a .zcode file, which I can't, because the problem is that I can't get the print preview to make the code.
(I could attached a different, but related zcode, like for the 0.14mm print for example, which does work)
Kyle
May 14, 2015, 10:26pm
6
They must have fixed it.. It shows up at .09 now.. Generates code and shows preview..
Version v1.0.1 has fixed this, thanks.
