Z-Suite v1.8.2 distortion
It looks like the Z-Suite V1.8.2 program is modifying the model that was loaded as a  .STL file.  I hope that the two figures that I attached are visible.
The first figure is what is loaded into the Z-Suite program and the second one is the result of clicking  > Print.
The second figure looks shallow compare to the original one. The cross-section of the original model is a semi-circle.
I'll appreciate if someone can tell what's going on.  The .stl file in english units is also attached. Thanks.4176
Walls are too thin
That was it. Thank you Marcin. Now I have to find the minimum thickness that will work, in order to save filament.
