Hi i installed z-suite on my computer and it will not start i got this error.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Exception: ProcessLauncher failed:System.ArgumentException: Process with an Id of 7248 is not running.
at System.Diagnostics.Process.GetProcessById(Int32 processId, String machineName)
at EO.Internal.jm.a(String[] A_0, String A_1, String A_2, String A_3, String A_4)
at EO.Internal.jm.a(String A_0, Boolean A_1)
at EO.Internal.awb.a()
at EO.WebEngine.Engine.Start()
at EO.Internal.cq…ctor(WebView A_0)
at EO.WebBrowser.WebView.v()
at EO.WebBrowser.WebView.Create(IntPtr hWnd)
at EO.WebBrowser.WinForm.WebControl.a(Object A_0)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1055.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Z-Suite
Assembly Version: 1.4.1.0
Win32 Version: 1.4.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Zortrax/Z-Suite.exe
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Z-Suite&
Assembly Version: 1.0.0.0
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Zortrax.View
Zortrax.View&
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EO.Base
Assembly Version: 15.3.24.0
Win32 Version: 15.3.24.0
CodeBase: file:///C:/Program%20Files%20(x86)/Zortrax/EO.Base.DLL
EO.WebBrowser
CodeBase: file:///C:/Program%20Files%20(x86)/Zortrax/EO.WebBrowser.DLL
OpenTK
Zortrax.Data
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Zortrax.Data&
Zortrax.GCode
Zortrax.GCode&
OpenTK.GLControl
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
EO.WebEngine
CodeBase: file:///C:/Program%20Files%20(x86)/Zortrax/EO.WebEngine.DLL
Microsoft.WindowsAPICodePack.Shell
Assembly Version: 1.1.0.0
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging=“true” />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box
