Z-Suite BETA V0.0.9 [ENG]
New Z-Suite features added:
As the first in the world, we added the option cuts the model in STL format (in test phase)
Added Shell option (Advanced tab) - this option allows you print only walls without top and bottom layer of the model (in test phase)
Added Mesh option (Advanced tab) - this option allows you print empty models, Z-Suite generate all walls but without infill (in test phase)
Improved quality for the top and bottom layers
Improved algorithm that generates infill
Improved algorithm which is responsible for the gap between the infill and the wall
Improved algorithm which is responsible for the seam - we aim to remove the visibility of the seam - still in test phase
Fixed problems with generating zcode for some models which have been reported
Fixed problems with removal RAFT and Support structure
Fixed ghost surface
How to update?
- Just open your Z-Suite®. Download should start automatically. You can download new version manually too, simply go to https://zortrax.com/support-center
MAC version will be available in 48h
