Z-Suite® v1.1.0 for Windows/Mac is here!
Z-Suite® v1.1.0
- Added printing material cost calculator
- Added new view options
- Added ability to disable the automatic generation of bridges
- Added checking whether the model has been loaded in the correct scale (inches, millimeters)
- Slightly improved interface readability
- Added possibility to load files by dropping them from other programs (for eg. compressed folders)
- Improved gap filling with thin walls (from 1.0mm to 1.5mm)
- Improved quality under the convex inscriptions on the top of the print
- Improved repair algorithm of the damaged .stl files
- Bug fixes
How to update?
- Just open your Z-Suite®. Download should start automatically. You can download new version manually too, simply go to http://support.zortr…ware/downloads/
