Can i use Z-Support ATP with Inventure?
Bart
Bart
Hello Bart,
Z-SUPPORT ATP is quite brittle so you would need to insert it directly to the extruder (not through the material guide) - otherwise, it could break inside the tube. Also, there are no dedicated ATP printing profiles for Inventure, so support structures might not fully adhere to the model material (warping). Moreover, you would need to change the extrusion temperature (240-260 °C).
