I’ve been loving the amazing surface quality printing with Z-Ultra on my Inventure. One thing I’m starting to notice is how good the final layer is, but how bad looking the bottom layer is. It appears that the Z-Premium support is maybe getting too hot, or has moisture, or some other issue that causing odd “blobs” to be formed on the raft layer. The texture of these “blobs” then show up in the parts first layer.
Any thoughts on how to prevent this?" I don’t recall seeing this using other print material like PETG so I was wondering if it was a temperature thing.
Hi. Does this happen with all models printed with Z-ULTRAT? Does this also happen straight after platform leveling and nozzle alignment? You may try to increase the fan speed in Z-SUITE. Also, can you send me .zcode and .stl file, please?
Thanks in advance for your help. Yes, it seems to happen just with Z-Ultra and Z-Premium Support. I’ve been using it with Z-PETG without any issue. I attached the files for reference. And I did perform leveling and nozzle alignment after switching to a black build tray.
You can see from the images that it seems to print fine on part of the raft…then it starts to get strange.
Is there a way to verify that the lower fan is working properly?
Also after reading online forum comments my understanding is that adjusting the fan speed in Z-Suite will only effect the lower fan speed after the raft is built. Is this correct?
Any thoughts on the previous fan question? I was wondering if fan output during the raft build was somehow not optimal. I’m just not sure how to test it while its going. Thoughts?
