onap
#1
Hello all,
When I print with Z-ULTRAT material, I've got sometimes spot on the printed part. But I havent this problem with Z-ABS
3239
I use last Z-Suite firmware
Select Z-ultrat material
0.19mm layer
V1 extruder (and cleaned before printing)
But the Z-ULTRAT spool I received from a french webstore doesn't look like other spool?
3238
Thanks for your help
Oli
Marcin
#2
Have you got any other Z-Ultrat spool to check?
edit: could be faulty batch tbh
voudas
#3
this is the new spool design.
did u use random seam setting?
onap
#4
No I don't use random seam. Will test with a new spool
