New printer to be released from Zortrax; The "Zortrax M200 Plus"
The Zortrax M200 Plus desktop 3D printer is an improved version of the Zortrax M200 and comes with features such as a touchscreen display, improved hotend and material end detection.
I have a question about the aluminum plate (and the heating plate) : I read that Zortrax will use connectors “pogo” for fixing the cable to the heating plate : could you say more ?
Is it easier to remove the aluminum plate ?
I also have a question about the nozzle : I also read that Zortrax will install a new nozzle 0,4mm : is it a nozzle compatible with abrasive materials (abs or petg + carbon or kevlar) ?
Hi axel,
See the connectors in the picture attached.
You can print with ABS and PETG on this nozzle as those are our dedicated materials for this printer.
At the moment I cannot share any info regarding a possbility of printing with carbon or kevlar.
I hope that Zortrax will be able to specify if it is possible to print filaments (NYLON, ABS, PETG) + kevlar, + carbon + fiberglass with this new nozzle of the V3 hotend of the M200plus.
It will be very important to know it quickly.
In my opinion, the lack of response blocks any decision to buy M200plus !
Today, thanks to Z-suite 2 and the hard Micro-swiss nozzles, these filaments can be printed successfully on the M200.
These special filaments greatly extend the scope and use of the M200.
I contacted Micro-swiss about it : they are not going to make a new hard nozzle for the M200plus. They are busy on other projects and have no time to develop this product for now.
If Zortrax indicates that it is not possible to use these special filaments, this implies that it will not be possible to consider buying Zortrax M200plus.
This would be a very bad sign from Zortrax who opened his Eco-system with Z-suite 2 and closed it with the M200plus!
Marcin,
Today, customers are more demanding : they want more information and more details about the printers before deciding for a purchase.
It is incomprehensible that Zortrax and the other manufacturers still continue in 2018 to ignore these legitimate requests and still hope that we, customers, will buy new products on the basis of a beautiful hollow marketing speech and beautiful images!
Do you plan to offer V3 Hotend for M200? and is there anything else that can be upgraded on the M200?
Not only the hotend is different but also the extruder block has been redesigned on the M200Plus and it works only on this product.
If you're patient enough, you could probably succeed in using it somehow. However, the quality may worsen as the hotend v3 is not dedicated for the M200 and not adjusted to this device.
