Zortrax M300 print with 0,6 mm nozzle?
Can you help me? I must print with a nozzle of 0,6 mm in my 3 M300… a very large file. Thanks
As for M300 - you can print with 0.6 mm nozzle with ABS/PLA-based filaments only. You need to set the nozzle size in Z-SUITE first. Also, you need to use a 3rd-party nozzle.
In the last Zsuite don’t can choose 0.6 mm nozzle… can you try? Thanks a lot
My bad - I am sorry. I must have mistaken the settings. I double-check that now and, unfortunately, 0.6 mm nozzle is not available for M300.
Can you up grade Zsuite to choose nozzle also in M300 model??? PLEASE!!! It’s very important for my job! I have 8 Zortrak’s machines (5 M200 and 3 M300)… Best regards Daniele
