We are looking to upgrade our M200 to probably M300 dual but after testing the same piece on ZSUITE the m200, m300 dual and m300 plus I dont see why we would upgrade. The printing speed is extremely slower than on the m200 despite me trying to replicate as close as possible the same settings.
14 hours versus 26 hours versus 19 hours
Application version: 2.16.2.0
Estimated print time: 14h 8m
Material usage: 39.29m (94g)
Printer: Zortrax M200
Profile: Last settings
Support type: Editable
Material: Z-ABS
Nozzle diameter: 0.4 mm
Layer: 0.19 mm
Quality: High
Infill: Mesh
Fan speed: 0%
Seam: Normal
Outer contours: 0.00
Holes: 0.00
Surface layers Top: 6
Surface layers Bottom: 6
Support Lite: No
Smart bridges: Yes
Support offset: No
First layer Density: 100%
First layer Print speed: 100%
First layer Flow ratio: 100%
First layer gap: 0.21 mm
Raft Enabled: Yes
Raft layers: 6
Platform-raft gap: 0.20 mm
Raft Density: 100%
Raft Print speed: 100%
Raft Flow ratio: 100%
Support Density: 4.00 mm
Gap XY: 0.53
Estimated print time: 1d 2h 17m
Material usage: 30.65m (73g)
Support usage: 8.75m (22g)
Printer: Zortrax M300 Dual
Support material: Z-SUPPORT ATP
Material: Z-ABS
Layer: 0.20 mm
Quality: High
Infill: Mesh
Fan speed: 0%
Seam: Normal
Holes: 0.00
Contour-infill gap: 0.35
Contour-top gap: 0.38
Surface layers Top: 7
Surface layers Bottom: 3
Support Lite: No
Smart bridges: No
Max. wall thickness: 3.13 mm
First layer gap: 0.20 mm
Raft Enabled: Yes
Raft layers: 6
Platform-raft gap: 0.22 mm
Raft Density: 100%
Gap XY: 0.16
Hybrid Support: No
Estimated print time: 19h 5m
Material usage: 40.62m (97g)
Printer: Zortrax M300 Plus
Material: Z-ABS
Layer: 0.19 mm
Quality: High
Infill: Mesh
Fan speed: 0%
Seam: Normal
Holes: 0.00
Contour-infill gap: 0.40
Contour-top gap: 0.25
Surface layers Bottom: 4
Support Lite: No
Smart bridges: Yes
First layer gap: 0.30 mm
Raft Enabled: Yes
Raft layers: 7
Raft Density: 100%
Support Density: 3.50 mm
Gap XY: 0.36
M200.zprojx (8.0 MB)
