Dusted off the Inventure in a attempt to print something that wasnt printing correctly on the m200. Well, it seems the old support material is no longer supported ( pun intended ). Anyways I printed with a single material and with a default configuration and its stuck real good to the platform.
Scraping it is real hard and takes forever.
Can I use acetone or any other chemical to save the platform?
Thanks for the help!
Application version: 2.16.1.0
Estimated print time: 12h 28m
Material usage: 31.24m (87g)
Printer: Zortrax Inventure
Profile: Last settings
Support type: Editable
Material: Z-ULTRAT Plus
Nozzle diameter: 0.4 mm
Layer: 0.20 mm
Quality: High
Infill: 30%
Fan speed: Auto
Seam: Normal
Outer contours: 0.00
Holes: 0.00
Contour-infill gap: 0.20
Contour-top gap: 0.35
Surface layers Top: 7
Surface layers Bottom: 4
Max. wall thickness: 3.13 mm
Support Density: 3.50 mm
