Support Team,
I need to know why does the printer is unable to de correctly calibrated
I level the machine.
I level the bed, according to Quickguide.
When I turn on the printer the X,Y Axis moves to the center. And gently touches the build plate.
Then the XY is set to home(front left corner)
It touches again gently the buildplate.
Then it gets back to the center, touching again.
Finally when it starts printing the platform is lowered automatically and when it prints the frontier layer on the front left side it is significantly lower than waht was set manually it does't sticks can be very easily peeled off by hand.
Then the whole rest of the model is just a complete mess....
I'm printing a big object, and I bought this machine for that purpouse and to have the whole plate filled with models all of them in diffrent possitions and obviously some of them will be in the corners.
Why does the machine makes this check?
It's completly useless if we are leveling the platform manually, why the machine needs to check for Z height and nozzle distance.
The machine makes a slight correction and this is giving me a lot of problems I can't print like this and the printer is completly useless I need the whole 205x205x185 to be effective.
I own an UpMini and this problem usually appear in one corner, but yo can't compare the hardware and price this machine is 1/3 the price of the zortrax and mechanically simple and even fragile, the bed is lower from a side adn is where yo usually have problems.
Can I have an earlier Firmware versiobn installed? so that the machine overrides this check of height?
