Hi Zteam,
When Z-Suite 0.0.6 was released the Firmware 0.0.4 was promised for nearly soon.
Any updates?
Hi Zteam,
Any updates?
Hmmm … ;)
And?
no frimware
So it's monday now, where is firmware 0.0.4? It was promised for Friday
You just got zortraxed!!!
lol... Andre is funny..
<_<
On a good note... You can still use your printer!!!! :D
<_< In fact printing right now :P
You and me both.. I have a 3 part job after this one.. :D
Z-Firmware v0.0.4 released
http://forum.zortrax.com/index.php?/topic/520-z-firmware-beta-v004-is-ready-to-download/#entry12617
Calibration will be much more useful if together with information that ie Back Right corner is to low/high it give a value, so I know if it's far to low/high or just a bit. I hope this is an easy enhancement and will be added in 0.0.5 :)
First impressions of 0.0.4 autocalibration: I had to perform it 3 times, then on the fourth it gave me the readings in the attached link right away. It does the back first, then moves to the front then when it is satisfied with the front it checks the middle and reports. It does not go back and check the back. So I did it again and it kept saying the front needed to be moved until the fourth attempt when it reported all zones were within spec.
https://www.dropbox.com/s/laq9dx49b6cnsxw/2014-07-10%2018.24.15.jpg
Dhatw.
Notes say this:
Added print cancellation option (push the button for 10sec)
So it's the same? if I push the button for 10 seconds I may have my print cancelled?
Read it carefuly. ;) You can choose what you want.
:P I was in a rush
Well, I just started a print after doing the calibration and getting the result in the link yesterday. The nozzle was rubbing really bad in the back and I aborted the print because I could hear the feed gear skipping. I was hoping to start an 8 hour print before I went out but now don’t have time to manually calibrate and wait for the full raft to finish. Disappointed to say the leastFirst impressions of 0.0.4 autocalibration: I had to perform it 3 times, then on the fourth it gave me the readings in the attached link right away. It does the back first, then moves to the front then when it is satisfied with the front it checks the middle and reports. It does not go back and check the back. So I did it again and it kept saying the front needed to be moved until the fourth attempt when it reported all zones were within spec.
Dhatw.
Well, I just started a print after doing the calibration and getting the result in the link yesterday. The nozzle was rubbing really bad in the back and I aborted the print because I could hear the feed gear skipping. I was hoping to start an 8 hour print before I went out but now don't have time to manually calibrate and wait for the full raft to finish. Disappointed to say the least
you platform is probably warped/bowed...since the cal does not check the rear center (for example) you could still be too high there if the platform is bowed up.
Try to straighten your platform using the methosd Rafal showed in the forum, I used it and it worked great.
