Windows 7 (US) zsuite pause doesn't work.
Windows 7 ultimate, SP1, PL - pause don't work
I have few questions:
Does Z-Suite display layers with pause in red color like on image below?
When you reopen saved zcode, are pauses displayed?
Can you, please, send your zcode with pause to support@zortrax.com?
Thanks in advance.
Yes, it displays pause like on image.
Yes, it displays pause after reopen saved zcode.
File sent
Pause works great :)
Windows 7 Home Premium
Some users had an issue with 0.0.4 FW - id din't want to load, and there was a fixed version.
kajdas.k>which version of 0.0.4 firmware you are using?
I'm using the very 1st one, I had no issues with update/using 0.0.4, so I didn't care about fixed 0.0.4, and I have printer V2
Foto
Print 0,14
kajdas.k> Share the slt please, and all the settings in zSuite, I will do same on my PC/printer and check, and we can send our files to support, so they will have exactly two, (probably same) files where one is working, 2nd should not :)
Z-CODE filament clip 6 psc.
https://www.dropbox.com/s/chw7u6f52m8byp5/FILAMENT_clip.zcode
Ok, here is my: http://poksms.pl/pobierz/FILAMENT_clip_slawek.zcode
YosemiteSam Clip
slaweks82
Your file works on my printer :)
Yes Zsuite does show layers to pause, It just runs past the pauses on mine.
Print file slaweks82
Work super.
I just started to print Yours.
Insert the pauses with mm height measurements DOESN'T WORK :(
Insert the pauses with the slider WORK :)
In the meantime I get new FW from support, and I give it priority, and I canceled Yours zcode print.
The result is that now BOTH: "slide bar" pause, and "at height" pause works for me.
If your "height pause" didn't work, please re-open your zcode, and double check if there is pause - check the code from SD card. Once I found that pause did not work for me, I verified zcode, and there was no pause at all, so I used "save as" instead of "save to sd card". I just found that "save to sd card" have a issues.
What is the new FW called? Will we all get an update soon?
I just double checked.
That's the issue I found with zSuite:
1. Run zSuite v0.0.8
2. Load model (I did small 2x10mm pipe), and prepare to print
3. Insert pauses (by height or/and by slide bar).
4. Use "save to sd card"
5. Open side by side another instance of zSuite and open file from SD card that you just saved - there is no pause !!!
6. Use "save as" and give it a new name (eg add suffix), and save on SD card
7. Re open this file in 2nd zSuite - you can see, there is a pause
8. Change pauses in 1st instance of zSuite, use "save to sd card"
9. Re-open - there is pauses, but the "old layout"
So you have to use "Save as"
