I’m using a M200 and since I have updated my macbook to IOS 26 Z-SUITE 2.32 does not start any more even after reinstalling it. here after is the crash report if someone could help me it would be good.
regards
Translated Report (Full Report Below)
Process: Z-Suite [25454]
Path: /Applications/Z-Suite.app/Contents/MacOS/Z-Suite
Identifier: com.zortrax.Z-Suite
Version: 2.32.0 (0)
Code Type: X86-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.zortrax.Z-Suite [3552]
User ID: 502
Date/Time: 2025-10-14 13:39:15.0616 +0200
Launch Time: 2025-10-14 13:39:10.0429 +0200
Hardware Model: MacBookPro16,2
OS Version: macOS 26.0.1 (25A362)
Release Type: User
Bridge OS Version: 10.0 (23P350)
Crash Reporter Key: 483EC70F-7557-BD13-EF3C-33C0C65791A0
Incident Identifier: 6000111D-5509-4571-B548-FB9B77F643EF
Sleep/Wake UUID: 23459EEB-CC72-46D5-AD87-00C0285CAD31
Time Awake Since Boot: 47000 seconds
Time Since Wake: 207 seconds
System Integrity Protection: enabled
Triggered by Thread: 24 Thread Pool Worker
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 5, Trace/BPT trap: 5
Terminating Process: exc handler [25454]
hello,
thank you to have a look on my problem and sorry for the mistake between IOS and MACOS, I will try to modify my original post.
I have done what you suggest and unfortunately ZSUITE does not start properly. here is the log of terminal :
see following posts. as forum does not allow me to put more than one link in a post I divided log in several posts.
regards,
The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
MacBook-Pro-de-Mathieu:~ mathieu$ /Applications/Z-Suite.app/Contents/MacOS/Z-Suite ; exit;
2025-10-22 13:35:16.762 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe98f57ea0 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
2025-10-22 13:35:16.765 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe98f63c10 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
2025-10-22 13:35:16.809 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe99a91570 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
2025-10-22 13:35:16.809 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe998365f0 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
2025-10-22 13:35:16.809 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe99837fa0 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
2025-10-22 13:35:17.143 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe99aae1c0 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
1 0x7ff9107e5673 WebKit::WebFramePolicyListenerProxy::ignore(WebKit::WasNavigationIntercepted)
2 0x7ff9107e6372 WebKit::WebFrameProxy::setUpPolicyListenerProxy(WTF::CompletionHandler<void (WebCore::PolicyAction, API::WebsitePolicies*, WebKit::ProcessSwapRequestedByClient, std::__1::optionalWebKit::NavigatingToAppBoundDomain, WebKit::WasNavigationIntercepted)>&&, WebKit::ShouldExpectSafeBrowsingResult, WebKit::ShouldExpectAppBoundDomainResult, WebKit::ShouldWaitForInitialLinkDecorationFilteringData)
3 0x7ff91081a97c WebKit::WebPageProxy::decidePolicyForNavigationAction(WTF::Ref<WebKit::WebProcessProxy, WTF::RawPtrTraitsWebKit::WebProcessProxy,
WTF::DefaultRefDerefTraitsWebKit::WebProcessProxy>&&, WebKit::WebFrameProxy&, WebKit::NavigationActionData&&, WTF::CompletionHandler<void (WebKit::PolicyDecision&&)>&&)
4 0x7ff910818e88 WebKit::WebPageProxy::decidePolicyForNavigationActionAsync(IPC::Connection&, WebKit::NavigationActionData&&, WTF::CompletionHandler<void (WebKit::PolicyDecision&&)>&&)
5 0x7ff91033db80 WebKit::WebPageProxy::didReceiveMessage(IPC::Connection&, IPC::Decoder&)
6 0x7ff910e4a3f2 IPC::MessageReceiverMap::dispatchMessage(IPC::Connection&, IPC::Decoder&)
7 0x7ff910893c59 WebKit::WebProcessProxy::dispatchMessage(IPC::Connection&, IPC::Decoder&)
8 0x7ff91035b981 WebKit::WebProcessProxy::didReceiveMessage(IPC::Connection&, IPC::Decoder&)
9 0x7ff910e237a9 IPC::Connection::dispatchMessage(WTF::UniqueRefIPC::Decoder)
10 0x7ff910e23be5 IPC::Connection::dispatchIncomingMessages()
11 0x7ff907c26a19 WTF::RunLoop::performWork()
12 0x7ff907c2840a WTF::RunLoop::performWork(void*)
13 0x7ff8081fa57d CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION
14 0x7ff8081fa51f __CFRunLoopDoSource0
15 0x7ff8081fa2da __CFRunLoopDoSources0
16 0x7ff8081f8ff0 __CFRunLoopRun
17 0x7ff8082af420 _CFRunLoopRunSpecificWithOptions
18 0x7ff814ab442f RunCurrentEventLoopInMode
19 0x7ff814ab7467 ReceiveNextEventCommon
20 0x7ff814c3f223 _BlockUntilNextEventMatchingListInMode
21 0x7ff80c501ca4 _DPSBlockUntilNextEventMatchingListInMode
22 0x7ff80c023841 _DPSNextEvent
23 0x7ff80cb3aea2 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]
24 0x7ff80cb3a975 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:]
25 0x7ff80c01acab -[NSApplication run]
26 0x7ff80c0063ac NSApplicationMain
27 0x108895208 26 ??? 0x0000000108895208 0x0 + 4438184456
28 0x108895023 27 ??? 0x0000000108895023 0x0 + 4438183971
29 0x100f69e83 28 ??? 0x0000000100f69e83 0x0 + 4311129731
30 0x100f69f61 29 ??? 0x0000000100f69f61 0x0 + 4311129953
31 0x1009a3a6e mono_jit_runtime_invoke
2025-10-22 13:35:17.495 Z-Suite[75942:2397451] Warning: The declared constraints for <NSToolbarItemViewer: 0x7fbe98f60970 ‘(null)’> were previously invalidated only because a declared constraint was snipped or manually deactivated. This indicates missing invalidation for a view’s changing state that affects its declared constraints. To debug, set a breakpoint on _NSViewRemovedDeclaredConstraintBreakpoint
Trace/BPT trap: 5
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
I am a newbie and no a Mac user (I am a linux nut):
Did you consider to switch the Zortrax m200 to marlin firmware and use on your Mac a linux based slicer as Ultimaker ?
I am saying that because I already use ultimaker slicer + Zortrax convert from gcode to zcode (which is not optimal). This is why I want to switch to Zortrax Marlin firmware to get a full control of my printer.
Hello
My Mac has an Intel processor so the video for ARM does not apply. I will try to put it in flight mode to see if it works or not.
In order to be able to print I’m currently using prusa slicer and gcode to zcode converter and I have also installed a W10 virtual machine with Zsuite but both solution even if they work are not perfect.
I have also tested the Marvin firmware but the nozzle does not detect the contact with the plate when I tried to launch the print … so I revert to zortrax firmware. If someone is able to print properly with marlin software I am interred on how they do. What slicer to use? Is there any specific option to chose for the Z axis calibration on start?
Regards
Dear mathieuw
Did your consider the idea of LuckyStrike94 on running Zsuite on AirMode able ? What was the result ? I am pretty sure that information could be useful for somebody.
What kind of error you’ve got (error #0XX) ?
Do your printer have a Z-sense or the conventional (nozzle contact the cooper square on the perforated plate) ?
I am still learning on Zortrax 3D printer maintenance…
I have trie to launch ZSuite in flight mode and now it launches properly. Thank you very much for helping me.
have a good day
