My v1 has the v2 feed tube with plastic insert, but it uses the old v1 block. My v3 printer has the complete v2 hot end with curved block. Both have high-temperature heatsink grease inside the heater and thermocouple cavities.
My filaments is stored in a sealed plasic container with with a eva dry dehumidifier. some filament came in a paper box, some came in a plastic bag, sealed but not vacuumed like the while filament came with the printer
I have had this before, and its been back the last week of so.
What is the support structure like when removing? Mine has been a lot harder to remove than normal in the last week, which is a sign that the nozzle is run hot.
This is caused by the screws holding the thermocouple and the heater coming loose.
I have just checked mine and they where loose again, I print 10-12 hours a night and should check this more often.
Oddly enough, yesterday I printed the same zcode in the same material on my two M200s - one a v1 and the other a v3. The v1 had no stringing while the v3 had quite a bit. It was easy to remove with fingers and a heat gun, but the difference between the two machines in this respect was striking.
Hello Julia, do you mean that it is better with the press of V1,
and V3 press “worse”?
Yes, but I wouldn't read too much into it - the two printers generally produce virtually identical results. As syue87 has told us, this issue can be related to extruder heating components, so it's not surprising to see some variation, especially since I'm using a v1 heat block on my v1 printer and a v2 heat block on my v3 printer.
I just started a print and noticed some stringing. This is the 4th (second on firmware 1.0 and software 1.3) one of the same part with slight changes, but none in the area that is stringing I have printed and none before had this problem. I am hoping it does not cause any issues since it is an 11 hour print.
Dhatw.
The print finished with no issues but there was some stringing and a tiny bit of hairs. Not much, but given I haven't had any since the very beginning of time with my M200 it is something to note.
