I have tried all I can think off to update the firmware on my M200 plus
I keeps giving me an USB error, I have tried several different USB’s no difference down loaded the file separately.
“UPDATE ERROR”
“Either the file or the USB flash drive is damaged try to transfer the file again or use a different USB”
I haven’t printed anything yet!
Think I have a bad printer?
I assume you have some older firmware version installed and you want to go directly to 1.4.0. Sometimes it gives such an error. Please try the following:
I’m getting this error trying to update from Ver 1-3-2 to Ver 2-1-3. Will I really have to do it one version at a time or will I be able to skip over a few?
Good morning even I can not update the firmware, I download the latest release 2.1.3 on the key supplied with the printer, but it does not keep me going. It tells me that I have the latest version available: 1.1.1
please help me
Hi, you need to install (via USB) 1.5.0 update.zar2 file which can be found in 2.0.0 folder. So the update process should look like that: 1.3.2 -> 1.5.0 -> 2.0.0 -> 2.1.3.
Hi, 1.1.1 is the old firmware. You will not be able to update to 2.1.3 directly. You will find all firmware versions here. Install the following versions in order (via USB): 1.1.1 → 1.2.0 → 1.5.0 (you will find the file in 2.0.0 folder) → 2.0.0 → 2.1.3.
Hi, I know this thread is old but I just ran into a similar problem: I have the old firmware 1.1.0 still installed on my M200 plus. Now with the new versions of Z Suite out my printer won‘t print the new zortrax files any longer. I want to update the firmware on my printer, but installing the latest update does not work. Reading through this thread it seems like I will need to update step by step using the older updates first. However, the older updates such as version 1.2.0 or 1.5.0 are no longer available on the Zortrax website. Approximately 2 weeks ago I described my problem on the Zortrax support website form and sent it - but no response from the Zortrax support team so far.
→ Is there any way that you can either send me the “older“ update files or make them available on the website?
Otherwise my beloved M200 plus will be dead…
Thank you so much!!
@DamianZortrax I downloaded the 2.0.0 firmware update, unzipped the folder and copied the update.zar2 file from the 1.5 folder onto the USB drive main folder where all the other folders and *.zcodes files are stored. I re-inserted the USB stick in the printer. After turning on the printer and being in the Launcher mode its display shows me that the current firmware is 1.1.0. When hitting the refresh button it tells me that the latest update is already installed. I rebooted several times but this doesn’t change the outcome.
Any ideas? Greatly appreciate your help with this matter!
@Damian94 any ideas of what I am doing wrong? If not, would it make sense to completely erase everything on the USB stick and flash the latest OS onto it? If so, where can I get the OS for the M200 plus hardware?
@Damian94 So I manually erased all files on the usb stick using my Mac. Then copied the two folders containing updates 1.5 and 2.0 on the USB stick. Inserted the stick in the printer: still same outcome - no updates dectected, current firmware v1.1.0…
Also tried only copying the update 1.5 on the stick, then both updates with no folder structures; no matter what I do, I always get the same outcome.
any other ideas? thank you!
