Hi Everyone,
I am having a problem during calibration or start of a print.
I recently replaced an older nozzle after i "accidentally" warped it with a torch attempting to clean it.
At first I thought the nozzle was dirty and would not contact with the bed.
With the new nozzle, I run into the same problem.
- When I calibrate, it starts in the rear left corner, and the bed jams into the nozzle, and wont stop. (I turn printer off)
- When I start a print, it starts in the middle, and does the same exact thing.
I have checked the connectors on the bed, and the nozzle is clean.
I even moved the extruder sideways just a little during the process to get a new contact point since the bed had an indent where it always touches.
No luck, except for it detecting it one time, and then crashing right after.
I have a new perf board coming in, in hopes of fixing this problem. (I think the indents have to do with it, as the metal surface was damaged from the crashes.
On a side note, I would love to have the option to manually control the zero before a print.
That is how I have always done it on a CNC machine to zero a tool with a piece of paper.
I know some other people have run into this problem in the forums but I have not found a solution.
Hope this sheds some light on this issue.
Best Regards,
Jack
