I have an M300 Dual, I have run out of support material. I wanted to ask if I can still print somehow? The print does not require supports.
In z-suite I turned off “raft” when I started the printout, the error “no material B” appeared. I deceived the sensor, but the support material is still printed.
Do you have any way to print in M300Dual like in regular M300?
I just found the answer to my question in this topic:
