i have a problem with the support when using Z-HIPS. The support stick to strong to the printed element and there is no way to get it rid off. Do you have any tips & tricks to sort it out?
Hi Albert,
My colleague is checking the files you sent her. She will let you know the results via e-mail. Could you also tell me whether the same problem occurs while printing with other materials?
Hi Albert,
I suppose you are using Z-HIPS as a single extrusion, and your issue is separating the Z-HIPS support from the Z-HIPS parts?
I have just requested that Z-HIPS is added to the dual extrusion materials list, allowing use of Z-Support Premium.
Regards
Sten
