Hi Zortrax,
Request: Allow using Z-SUPPORT PREMIUM support with Z-HIPS in Z-suite.
(Add Z-HIPS to dual extrusion materials list).
Problem:
In the current version of Z-suite (2.18.00) it is not possible to select Z-HIPS with Z-SUPPORT PREMIUM or ATP. - Only single extrusion with Z-HIPS is allowed.
Z-HIPS can at the moment only be printed using itself as support material, which contrary to how the material is advertised does NOT work well. - It is impossible to separate the support from flat supported surfaces (see other posts about this - here: Problem with the support when using Z-HIPS).
Solution:
I have managed to test Z-HIPS with Z-SUPPORT PREMIUM by using External Materials settings and guessing temperatures etc, - and the materials work well together. There is good adhesion to the raft.
Please go ahead with this change, which will increase the usefulness of Dual Printing and use of both Z-SUPPORT PREMIUM and Z-HIPS.
Kind regards
Sten
