Z-SUITE 1.10.0 External Materials Feedback
Post feedback here
I'm finally the owner of my printer, so many things still have to be printed
When do you use wifi as a contract?
Wow - it's a Big Boom :)
Too bad it is still the same error with thin walls and no infill between them.
I'm not sure if I follow, wifi as a contract?
Yea, I've reported it straight back from bugtracker but we haven't got time to fix it.
Wifi connection is one of the features for which I bought this printer !!
you understand now ?
yeah, but after bunch of test we've decided that SD card is much more reliable. We dont leave it completely behind but for now - SD wifi cards are only option.
just one thing...THANKS
i think next step can be nice the option of the raft removing ( for PLA ) and the printing with offset ( if someone desire print into a layer of glass for example )
and also the annoyng problem with no infill into walls
is TOP !!!
thanks for Zortrax !!!
… … now we try new materials … new life for Zortrax !!!
I can not download it.
Version 1.10 is a tremendous step forward and opens up to other plastics.
But it is still missing the possibility of changing the T ° of loading and unloading of the filament. For the PLA for example.
It would also be necessary to be able to memorize a printing profile when using the group of "external materials"
I can not download it.[/size]
Turn off AV software, there is nothing that could harm your PC in any way.
Have not tried it yet but external materials - AWESOME!!
Marcin ja wiem, że jest jakiś harmonogram, itp itd ale to tłumaczenie brzmi trochę jak kawał o pustej taczce.
Kowalski na budowie biega z pustÄ… taczkÄ… w te i we wte. WidzÄ…c to kierownik pyta:
  • Kowalski, a ty co tak z tÄ… pustÄ… taczkÄ… latasz?
  • Panie kierowniku - mówi Kowalski - taki zapierdziel, że nie ma kiedy zaÅ‚adować…
So how open is the temp settings?
He Marcin,
for first, really thanks to you and zortrax team for this important zsuite update.
For second, what kind of feedback u need ?
For now i did 2 print (5 and 3 hours) using abs-style with 100 degrees on plate and 245 degrees estruder temp, at -25% of speed increasing at 125% the bottom layer.
And it seem works very very fine.
For example i'll use the abs-style profile for z-abs material too, reducing the temp at 245-250 especially for white orange and "clear" colors :)
290 for extruder temp and 105 for plate.
Cool thanks, and how low can we go ?
Mate, download it and take a look ...
Yeah, I will but it will take some time until. Just super curious. :)
Thank you! Finally Zortrax will become printer also for pros not only noobs. Kudos for person who convinced the Z-board to make these changes.  :)
