Z-SUITE 3.6.0 BETA has just been released.
Full changelog:
- Added new printing profile Z-PLA (single mode) for M300 Dual,
- Performance improvements: the program now uses .NET 8.0.
You can download Z-SUITE 3.6.0 here.
Feel free to share your feedback.
Full changelog:
I can’t see the 0.6mm nozzle for the M300 dual?
When I try to print this with default settings for APS on the M200 Plus on either Z-Suite 3.5 or Beta 3.6, one of the holes is missing. The holes are both there in the STL, but after the Preview step, one of them is missing.
Base12.stl (212.1 KB)
Strangely, if I rotate it around the Z axis by -46 degrees (not 45 degrees though), then it renders OK.
Will it at some point be possible to view the camera preview full screen when connecting locally as you can do when using inCloud?
Hi @Red-UK
You can use the camera preview locally, by disabling the “Use Zortrax inCloud” option in Z-Suite application settings.
We are aware of the issue, and pinned down the possible cause. You might expect a fix soon.
The fix for Z-Suite for macOS 15 is now live. You should try to re-download the installation package to try it.
When viewing z-suite in Japanese, the thin walls are displayed in Korean.
I have a M200 and would like to understand which version of Z-suite that is teh latest with support for M200. Where can I find this information?
