Z-Suite software cannot be used
#1
This screen is presented after the software update in March
Tried some methods but no improvement
  1. Delete Z-Suite_v2.14.0_Win and turn off the computer, then reinstall Z-Suite_v2.14.0_Win
  2. Delete Z-Suite_v2.14.0_Win and turn off the computer, then reinstall Z-Suite_v2.10.0_Win
    Is there any suggested way to solve the problem
#2
Are you able to start 2.12.3 or any other version? What is your system version?
Make sure you have latest .NET Framework and Visual C++ 2013 and 2017 installed. Also, do you have two graphics cards installed? If yes - please, disable one. Most probably this is the cause of the problem.
Hey there,
I had a similar issue in the past.
You can check out my original post here: Z-Suite not displaying correctly after new Win Update
good luck,
-ryan
#4
Thanks for your answers
I found the problem
I have two graphics cards
A: The display card of the computer itself
B: Expanded graphics card
At first,DP cable was plugged in A
The problem was solved after plugging the DP line in B.
#5
Thank you for sharing a solution with us.
